02-28-2024 12:23 PM
I recently purchased 4 ICX 7450 switches. The make is by Brocade not Ruckus. Is it possible to use the current stable firmware with these switches. I read that it is supported, but I am getting errors trying to write to flash.
"The code type 64 is not correct for the target hardware, abort!"
"File type check failed"
"TFTP to Flash Error - code 8"
02-28-2024 12:30 PM
Hey @kransom
Yes, you can. Please double-check the image type. If you are coming from very old code, you may need to use 8080f as a step upgrade. The upgrade process will look like this:
*SPR image denotes routing code while SPS denotes switching code. You can check in 'show version'
While on 8030-8070 the commands will be:
copy tftp flash <ip address of TFTP server> <boot-code-image> boot
copy tftp flash <ip address of TFTP server> <OS-code-image> <primary/secondary>
Example for 8061 > 8080f (assuming router code and ICX7450)
copy tftp flash 192.168.1.250 spz10114.bin boot
copy tftp flash 192.168.1.250 SPR08080f.bin primary
wr mem
*reload into 8080f*
Once booted to 8080f:
*wait for POE firmware upgrade if applicable - happens automatically and can be seen on console or 'show log'*
wr mem (this is necessary to ensure your configuration is upgraded as syntax can change)
copy tftp flash <ip address of TFTP server> <UFI-code-image> <primary/secondary>
Example for 8080f > 8095m (assuming router code and ICX7450 again)
copy tftp flash 192.168.1.250 SPR08095mufi.bin primary
wr mem
*reload into 8095m*
wr mem
*if needed, POE firmware will upgrade again*
If this resolved your issue, please click 'accept as solution'.
