10-31-2023 05:05 AM
Hey Folks,
is there special trick configuring Ethernet Ports in SmartZone v-SZe Controller?
When i select a Port and click "Configure" we always get this error:
What I am missing?
Regards
Peter
10-31-2023 05:59 AM
Hi Peter_riederer_
Thank you for reaching us.
10-31-2023 06:09 AM
Hello Chandini,
the Switch is just fresh out of the box. There is no configuration on any port so far.
IP via DHCP, SmartZone Management enabled and Firmware-Update to the latest Version.
i thought i will be able to configure the vlans to the port bei clicking "Configure"
Regards
Peter
10-31-2023 07:24 AM
Hi Peter_riederer_
Ack and Thanks for reverting.
Correct you should be able to view port settings when you click "Configure" options.
Link reference:
Could you help me with below information:
10-31-2023 07:30 AM
we are using v-SZe with:
Controller Version 6.1.1.0.959
Control Plane Software Version 6.1.1.0.446
AP Firmware Version 6.1.1.0.1274
Switch Firmware: RDR10010a_cd3
Cli is working without any issues from v-SZe
