Cisco Switches not seeing VLAN from Ruckus/Brocade Switch
amathias
Hi all,
I'm having an interesting issue with the Ruckus/Cisco switches on our campus.
For context, we had a scheduled power outage at our site back in December, and when power was restored, we started seeing this issue. We have all our core equipment on a generator and did not lose power. No configuration changes happened according to our backups.
Our core switch is a Ruckus ICX7650-48F. After power was restored, I could not ssh into any Cisco switch directly connected to the core. Any HP/Aruba device directly connected works with SSH and ping. The same is true for any cisco device downstream from an HP/Aruba. Our management vlan is broken between the Ruckus and Ciscos, but I need help finding where.
Although this is happening, everything around the site is running fine from an operational standpoint. We have wireless and all ethernet working.
We have a Cisco 3650 directly below the core in the rack that I've been troubleshooting. When I checked spanning tree on it, I noticed a VLAN ID mismatch with two different VLANs. Our management VLAN 4 and the Trunk VLAN 666. Nothing has changed in the configuration, and I've double-checked that there isn't a mismatch like it says. I get this error with all Cisco switches.
Below is an attachment with config and spaning-tree results from both the Ruckus and Cisco. If you need more let me know and I'll post it as well.
Thank you!
Show run
Ruckus ICX7650-48F:
vlan 4 name NetMgmt by port
tagged ethe 1/1/31
spanning-tree
vlan 666 name TRUNK by port
untagged ethe 1/1/31
spanning-tree
Cisco 3650:
interface TenGigabitEthernet1/1/3
 switchport trunk native vlan 666
 switchport mode trunk
show spanning-tree
Ruckus:
show span vlan 4
PORT 1/1/31 - FORWARDING
show span vlan 666
Cisco:
show spanning-tree vlan 4
VLAN0004
  Spanning tree enabled protocol ieee
  Root ID    Priority    32772
             Address     006b.f1df.9480
             Cost        8
             Port        10 (GigabitEthernet1/0/10)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32772  (priority 32768 sys-id-ext 4)
             Address     f44e.0566.f780
             Aging Time  15  sec
Interface           Role Sts Cost      Prio.Nbr Type
Te1/1/3             Desg BKN*2         128.51   P2p *PVID_Inc
show spanning-tree vlan 666
VLAN0666
  Root ID    Priority    33434
             Cost        8
  Bridge ID  Priority    33434  (priority 32768 sys-id-ext 666)
             Aging Time  300 sec
1 REPLY 1
BenBeck
At a high-level, it looks correct: tagged vlan 4, untagged vlan666 for port 1/1/31
I would check layer 2 mac learning, arp, ping, etc. I would try to decipher if the data path is okay and if something is happening with SSH/Mgmt itself.
The best bet would be to open a support case (see my signature) and we can help follow the breadcrumbs.
