06-23-2025 10:08 AM
is it possible to daisy chain another poe+ or does it have to be poe+ to power an extra ap from the icx 7150? I have extra cables I need plugged in and im adding a 3rd ap to the switch and I just want to check that the ap will run on the added switch and if it has to be poe powered or not to make it work.
06-23-2025 06:05 PM
Hi Mcgruff28,
Yes, you can connect an unmanaged PoE or PoE+ switch to your Ruckus ICX 7150 to power additional APs.
A few key points to keep in mind:
So yes — you can daisy chain a PoE+ unmanaged switch to your ICX 7150, plug the AP into that switch, and it will work, as long as the AP gets PoE and data properly.
Note: Please feel free to mark the post as ACCEPTED SOLUTIONS if its addressed your query.
Kayal
