Announcement: RUCKUS FastIron Documentation Updates Published on RUCKUS Support Portal
jenniferbush
RUCKUS Team Member
2 REPLIES 2
inphobia
Contributor
regarding: RUCKUS FastIron Command Reference Guide, 10.0.20
is there any specific reason to introduce a command with an underscore? (ttl_threshold)
looking through the reference i can only find 2 other uses of an underscore:
"show ipc_stats", which at least on my 10.0.10c_cd4 & 10.0.10d very much doesn't work.
"ipv6 icmp fragment_header_bit", not sure why it says "... or equal to 1280", i think it should just be "less then" without the "equal", at least according to rfc8200&2460
inphobia
Contributor
@jenniferbush wrote:
RUCKUS FastIron Layer 3 Routing Configuration Guide, 10.0.20
nitpicking, but https://support.ruckuswireless.com/documents/4740 (the 10.0.20 l3 guide) for some reason is named the "FastIron 10.0.20 (GA) Layer 3 Switching Configuration Guide" in the overview & the direct link i gave.
the actual docs on commscope do call it the layer 3 routing guide, which is also how all other l3 guides are named.
here's what i mean, quick search on layer 3 in the docs:
Type a product name
