what is this problem ?
nirben
i have ruckus r300
Nov 5 10:18:11 RuckusAP daemon.err wsgclient[441]: crResloveAddrInfo:152 getaddrinfo failed, ret:-2/Name or service not known
Nov 5 10:18:11 RuckusAP daemon.err wsgclient[441]: cmrInit:138 Call 'crDefSocketInit()' failed, ip: port:443, ret:124/CR initial socket failed
Nov 5 10:18:11 RuckusAP daemon.err wsgclient[441]: communicatorInit:364 Init connection failed, ret:124, connectRetry:13477
Nov 5 10:18:11 RuckusAP daemon.err wsgclient[441]: registration:594 Failed to init socket! ret:124 url:https://RuckusController/wsg/ap
Nov 5 10:18:16 RuckusAP daemon.err wsgclient[441]: crResloveAddrInfo:152 getaddrinfo failed, ret:-2/Name or service not known
Nov 5 10:18:16 RuckusAP daemon.err wsgclient[441]: cmrInit:138 Call 'crDefSocketInit()' failed, ip: port:443, ret:124/CR initial socket failed
Nov 5 10:18:16 RuckusAP daemon.err wsgclient[441]: communicatorInit:364 Init connection failed, ret:124, connectRetry:13478
6 REPLIES 6
Vineet_nejwala
Hi @nirben
The error shows that the AP is failing to connect on port 443. Just to clarify the APs talk and connect to vSZ using port 443 and 22, if there is any firewall between AP and vSZ please allow these two ports.
Best Regards
Vineet
nirben
but how can i do it?
can you contact me please? @Vineet_nejwala or how can i contact you?
Hi Nirben,
For that you have to open a support case with RUCKUS support and available engineer can help you.
May I know if this AP needs to join a controller or running on standalone mode?
Syamantak Omer | Sr.Staff TSE | CWNA | CCNA | RASZA | RICXI
@syamantakomer it runs standalone mode , and i tried to but they help only for business customers
