02-20-2023 11:00 AM
Hi all,
I have a r710 on latest firmware 200.13.6.1.319 and I only getting 70Mbps on 5ghz and my internet speed is 1gig. Any ideas? I have hard wire tested from the cable modem to the ethernet plugged into the AP. Thanks!
02-20-2023 07:29 PM
Hi @Ed-E
The client is having a bad signal quality -68 and MCS rate is 2. I see that the client is tested by placing right next to it, can you tell us how the AP is placed? Is it mounted on the sealing or place on the bench?
Are you seeing the same RSSI with APs on other rooms as well?
