I have set up a new network that has several SSIDs and it also has iPads that connect to just one of the SSIDs for control purposes.
1 x ZD1106
6 x ZF7363
If I hide the SSID the iPads won't connect, as soon as I untick the hide SSID option the iPads connect straight away.
Of the 6 SSIDs in the system I only want to display two of them User and Guest. The iPads sit on a specific SSID that gets them on the Control VLAN, I would rather this wasn't visible.
Is there anything I can do in the ZD to help the iPads connect?
Thanks,
Gerrad.
