iPads not connecting to hidden SSIDs
I have set up a new network that has several SSIDs and it also has iPads that connect to just one of the SSIDs for control purposes.
1 x ZD1106
6 x ZF7363
If I hide the SSID the iPads won't connect, as soon as I untick the hide SSID option the iPads connect straight away.
Of the 6 SSIDs in the system I only want to display two of them User and Guest. The iPads sit on a specific SSID that gets them on the Control VLAN, I would rather this wasn't visible.
Is there anything I can do in the ZD to help the iPads connect?
Thanks,
Gerrad.
5 REPLIES 5
keith_redfield
Valued Contributor II
You are using DPSK/Zero-IT, correct? We believe this is an issue with a recent change Apple made to their security policies. Right now, visible SSID's are the workaround, though I realize that's not optimal for you. We are researching the issue for a better resolution.
keith_redfield
http://support.apple.com/kb/HT4199
Image_ images_messages_5f91c407135b77e247926078_79368e77b864d14b3e8defadeffb4de7_applenote_inline-3dcda849-6260-4185-949d-d8c3c1a00793-1665744870.jpeg1382207900
lots of posts on Apple forums as well (though it appears this issue had come and gone several times over the years)
keith_redfield
BTW Android won't connect to hidden SSIDs either (apparently never would), though interestingly a Macbook Pro running 10.8.5 had no issues.
Thanks for you input Keith that is helpful.
To answer your question, no I am not suing zero IT. Just standard SSID and PSK.
The only reason I want to hide it is for neatness, it would be preferable for the user not to see an SSID they can't use but that isn't vital.
Thanks,
Gerrad.
