06-02-2023 12:05 AM
how to downgrade ruckus r550 unleashed to solo firmware
06-02-2023 12:11 AM
Hi @rajeshyadav
If the Unleashed AP is a Master, then you ca login to the AP GUI, then go to Administration >> UPgrade >> then upload the below standalone version.
https://support.ruckuswireless.com/software/2764-ruckus-solo-access-point-114-0-0-0-5585-ga-refresh2...
If you are not able to login to the AP, then login to the CLI and follow the below instruction using FTP or TFTP:
- Standalone AP can be upgraded via CLI through FTP/TFTP. - Download the AP image file from the Ruckus Support Portal and follow the below procedure to upgrade the AP via CLI. - Place the image file in the root directory of FTP/TFTP sever. FTP: fw set host <FTP server IP address> fw set proto ftp fw set user <FTP username> fw set password <FTP password> fw set control <image file name> fw update reboot TFTP: fw set host <TFTP server IP address> fw set proto tftp fw set port 69 fw set control <image file name> fw update reboot |
07-23-2025 09:18 PM
unable to locate the .img file
can share it?
07-23-2025 11:35 PM
Hi Paramasivam,
Solo firmware file extension is .bl7 and you can download latest solo firmware for R550 "118.2.0.0.875.bl7" from link: https://support.ruckuswireless.com/software/3855-ruckus-solo-access-point-118-2-0-0-875-release-r550
Kiran Raval
07-24-2025 01:10 AM
Hi, I'm converting Unleashed to Solo for AP R550.
When click upgrade (firmware) it not accepting .bl7
preparable .img (do you have it?)
