12-28-2022 12:57 AM
system:SZ-100 AP:R310
how can i disable ap 5ghz.i have already disable the 5ghz in the group.but the APs in the group can not autodisable the 5ghz.
in the room my moblephone connect wifi well through 5ghz,can not connect the internet,but connect wifi through 2.4ghz,can connect the internet well.
how can i use CLI or other way to disable the 5gzh.
by the way if a hotel building,each room have a AP,what is the plan to set the APs setting.like channel....
01-02-2023 12:07 PM
Hello AaronKong,
There is no direct way to disable the 5GHz radio (or 2.4GHz radio) from AP groups. However, you can create a "WLAN Group" and uncheck all the WLANs in that group. Next, go to the AP group and select the WLAN Group under Radio Settings :: Radio B/G/N (5 GHz). This will effectively disable all the WLANs in 5 GHz radio for all those APs that are part of that AP group.
For AP channel, we have channelfly that chooses the best channel for each AP automatically
