Showing results forย
Search instead forย
Did you mean:ย
could not access AP T610 to configure.
hello everyone,
I am using ruckus outdoor AP T610. But I could not access to it to configure.
My devices:
1. Access Point outdoor AP T610
2. PoE TPLink TL-POE150S
My diagram:
Switch <---> PoE <--> PoE port in AP T610.
then I see the light PWR is green, and CTL is slow flashing green. Then I connect to SSID Configure.Me-27****, then it notifies: No internet. And I could not access the address: https://unleashed.ruckuswireless.com, also https://192.168.0.1
I tried to reset the AP, but nothing to change.
My purpose: I installed virtual Smart Zone, so i will use it for managing the ruckus AP.
Could you please give me advice? Thanks a lot!
-T
5 REPLIES 5
Hi Thedavewarren,
If you're looking to configure a new T610 AP, here's how:
  1. Access the AP using its default factory IP address (192.168.0.1) via SSH.
  2. If the AP is connected to a network and obtains an IP address via DHCP, use SSH (for example, with PuTTY) to access the AP using its assigned IP address.
  3. Once you have access to the AP with default credentials, manually assign the Smart Zone IP address so the AP can send discovery requests directly to the controller.
Let me know if this helps and If you have any questions or need further clarification, feel free to describe your exact issue in more detail.
Warm Regards,
Jatin Arora
