convert unleashed ruckus r610 to standalone ap
alan_tam_ell5st
    I will like to convert ruckus R610 to standalone AP that can managed by Zone director 1200 with firmware 9.13.3.0 build 41. What is the firmware that I need to download?
    Thanks.
alan
7 REPLIES 7
DarrelRhodes
Valued Contributor
Hi Alan,
You need the standalone firmware, download it from our support site here: https://support.ruckuswireless.com/software/1727-zoneflex-solo-access-point-110-0-0-0-663-ga-softwar...
Once the AP is connected to a ZoneDirector, it will be given another new ZD-specific firmware image by the ZD.
I'd recommend factory-resetting the AP after you've changed the firmware image.
Hope that helps,
Darrel.
any one there
alan_tam_ell5st
Thanks a lot for your value information. I will try to download the firmware that you mention.Is the any different between indoor ap software and solo access point software.
Thanks again.
Alan
DarrelRhodes
Valued Contributor
Hi Alan,
All APs, whether indoor or outdoor have their own, specific, firmware version for each of our software platforms: SmartZone, Unleashed, ZoneDirector and Stand-Alone.
Thanks,
Darrel.
