12-02-2020 06:45 AM
i am unable to Flash the old ZF7982s that ive replaced in my network back to the standalone firmware they are currently on
3.6.1.0.354 and i want to use them as standalone elsewhere ive tried to put these firmwares on zf7982_9.7.1.0.17.BL7 and zf7982_9.6.1.0.15.BL7 but they dont work either via web interface or via CLI & TFTP the error i get is
net_get_flash: **Err:Upgrade/Downgrade from FSI to UI is not allowed.**
AIS cleanup : Completed
** AP Image Signing : Upgrade/Downgrade from FSI to UI is not allowed.**
**fw(15364) : Unknown
from reading around it looks like i may first have to get them onto a SmartZone 3.4 or 3.5 Firmware before i can flash them with the Standalone Firmware would this be correct and if so where could i get a 3.4 /3.5 AP SZ Firmware?
I just quite like to use one or two of these at home as they are still pretty good APs seems a shame just to have them as paperweights.
12-02-2020 07:01 AM
Hey Gordon, you can typically find the firmware at support.ruckuswireless.com by searching the firmware # you're after. You seem to be clued in anyways, but just be sure to grab the version for your AP model is all.
Eg:
https://support.ruckuswireless.com/software/529-zf7982-firmware-9-7-1-0-17
https://support.ruckuswireless.com/software/529-zf7982-firmware-9-6-1-0-15
I can't recall if there is a required downgrade path, or if you need to factory default and then apply the updates once you come off SZ firmware.
12-02-2020 07:08 AM
Hi Gordon,
Correct you have a full signed image on the AP and you try to upload a non signed image.
I would suggest you use version 104.0.0.1347 that you can download from support site.
It can be used for stand alone also.
Regards
Martin
12-02-2020 07:58 AM
Thankyou thats worked 🙂 now i can reuse them yeah! - strange that that download doesnt appear when you look at the AP i wouldnt have thought to serch for that and the AP isnt mentioned in the list but the firmware is in the zip 🙂
04-21-2023 08:59 PM
it worked for my R700 AP, Thank you verymuch
