ZF7982 AP unable to setup wireless
leon_smaltto
Hi guys any help with setup, Logged in to set up the wireless but could not find where to enable the radio to set up my wireless, attached screenshot if anyone can help .planning on using it as standalone AP
Image_ images_messages_5f91c3e5135b77e2478d27b1_30b4c87872445ffd7dfbb83d8a2a0b52_RackMultipart20180206353301d85-0e092a4f-e0ad-4c78-86e1-e7eead311879-369431048.png1517890200
27 REPLIES 27
Hello Bart,
Kindly do a Factory reset to the AP and then upload 104.0.0.0.1347 version (.bl7 extension). If the error persist please reach out to using below method.
You can open a case via WEB through below link :
https://support.ruckuswireless.com/cases/new
or call Support https://support.ruckuswireless.com/contact-us
Best Regards
Vineet
i think it worked 🙂 🙂 🙂 🙂   thx for feedback
You're welcome Bart, you could use the above links for your reference for opening support case with Ruckus.
Best Regards
Vineet
martin_martin
Valued Contributor
Correct as Gupta and Thomas mentioned, you need to flash the AP to the latest standalone version which is 10x.x.x.x
regards
Martin
A little confused here what's the difference between 9.8.30.14 all aps vs Solo access point 104.0.0.0.1347 ga
