07-23-2015 07:13 PM
07-24-2015 03:06 PM
The R710 is the first Ruckus that does LACP. The other ports are usually for wired client connectivity (or sometimes another AP, in case your cable path is difficult).
As far as throughput, I'd say just to make sure you're connected to the gigabit port on the AP. It's unlikely that you will max out the Ethernet, as wave 1 AC would require beyond perfect conditions to push 1Gbps when overhead is concerned (no interference, 100% 3-stream AC clients, etc), and wireless is half-duplex anyway (where Ethernet isn't).
Basically, I wouldn't worry about the "only" 1Gbps Ethernet. You're going to get the best you can even without LACP, because the airtime is going to fill up first.
07-24-2015 03:40 PM
