We were supplied with 14 R320 and a zonedirector 1200, why is the R320 not showing as Mesh supported?
stephen_hughes_
Are the R320 mesh compatible on the zonedirector?
3 REPLIES 3
logan_taylor
Meshing functionality is not supported on R3XX ap's you would be looking at R5XX upwards.
Mesh is when you are not supplying a network cable to an AP and using it as a repeater.
Hope this helps.
stephen_hughes_
Thanks, thought the people who supplied the kit were experts 🙂
abilashpr
Contributor III
Hi Stephen,
Mesh is not supported by default on R300/R310/R320, if I need mesh I would prefer R510 else I would use R310 which would serve the purpose and save some
Type a product name
