Way should i bother upgrade ZF7372 to 100.0.0.0.127?
beppe_st_lbrand
Ruckus can't supply release notes for a regular user.
If i known this before we decided to go for ZF7372 i should have look for other products.
Never seen this kind of weak support model.
Kind regards,
Beppe
20 REPLIES 20
daniel_m
Contributor
So the Release Notes mention 100.0.1.0.45, but I can’t find this anywhere. They also mention a “What’s New in Ruckus Wireless Access Points 100.0” document, but I can’t find this anywhere either.
john_d
Valued Contributor II
Even as a Premium Support document, I've only got access to the same release notes file, that indeed does refer to an unreleased 100.0.1 firmware. This is not really unusual though -- I've seen previous 9.9 and 9.8 release notes refer to unreleased firmware versions before they become generally available.
As an end-user, I've not noticed many changes in 100.0 firmware for standalone customers. It seems to primarily deliver the benefit of single SKU cross-compatibility with all Ruckus configurations (ZD, SCG, etc). Michael mentioned that this firmware might have a fix for standalone mode band-balancing.
I did notice as a bug/regression, my standalone AP now creates the "island-XXXXX" SSID's. But other than that, I've not noticed any performance difference or noticeable Web UI difference in standalone mode on 100.0 vs 9.8.1.
Esteemed Contributor II
Ruckus new base image AP firmware 100.x has been posted to the Support site firmware Downloads page since Feb 2015.
daniel_dedisse
still get the island-xxxx ssid with 100.1.0.0.194 on each reboot even with mesh disabled
I just started a new post on the topic of Island SSIDs, and put together a KBA with details.
https://support.ruckuswireless.com/answers/000004423
