I have a hotel with mostly r600's and I've been getting reports of dropping connections. In my tests the signal doesn't actually drop, but when one client starts a transfer such as an internet internet speed test or if I do a Speedflex test on the management vlan, I see a very noticeable degradation of another client at least on the same AP. Running a ping just on a client to the firewall inside interface (Different or same vlan), the response times will start climbing and eventually start timing out until the speedflex test finishes on the other client. This is causing all sorts of issues since everyone seems to run a speed test when they have a slowdown and then its downhill from there as every speed test makes it worse until they all give up. Is there anything in particular I should look into to identify what might be causing this? Thanks
