11-03-2021 10:55 AM
When I'm using my home router as a AP and when I'm connected to it and using Hik-Connect app on which is set public IP (which ISP assign to me) and the port which the IP camera use, there is no issue and I can see it, but when I stop the wireless network on my home router and connect to it the Ruckus AP, after that I connect to Ruckus AP and using Hik-Connect app with same setting as above I cannot see the IP camera.
I can see it only when I set the private IP which is assigned to the IP camera in Hik-Connect app.
Could you please help me to solve this issue?
Best Regards
12-22-2021 10:46 AM
Looks like IP camera is resetting the TCP session.
12-29-2021 05:59 AM
I checked, but I cannot found what protocol is using the IP camera.
Best Regards
01-03-2022 11:05 AM
In that case, it is bit hard to find out what is causing the issue.
One thing I am sure of, camera is sending TCP RST packets, which means TCP 3 way handshake needs to be done again.
If I look at the destination port, it is TCP port 8005 and it is used for a Windows System Process.
01-04-2022 11:58 AM
Happy New Year.
I will try to ask the manufacturer about what protocol the IP camera uses for service/device discovery.
TCP port 8005 is server port and is using by the Hik-Connect app to run the camera.
Best Regards
01-04-2022 12:06 PM
@nikolay_danev in that case, TCP session is terminated by the server app.
