=:^) Did they offer you support where you bought your two Unleashed APs?
But please look under your Master AP settings, I think you have this feature.
Toggle your settings from "Optimize for..." and try Compatibility or Performance,
seems to be the best way to find your client optimal throughput settings.
Under System -> Country Code -> Channel Optimization.
...and if you don't see this now, from System & Admin (Admin & Services in later releases) -> Administer -> Upgrade
you will see an upgrade method. All but our first releases had Online Upgrade (Cloud) option, to latest release (no charge!).
We don't restrict our Unleashed knowledge base articles, nor firmware downloads:
https://support.ruckuswireless.com/software/1810-ruckus-unleashed-ap-200-6-10-1-312-ga-refresh2-soft... but you need at least a "Guest" account on our Support portal,
https://support.ruckuswireless.com/registration ...which I assume you must have to be participating in the Forums?
I'm our company NPI engineer for Unleashed too, and I think it's a great small business/home user product.
PS. I reset the KBA-8555 permissions, which should have been Public, not Premium.
https://support.ruckuswireless.com/articles/000008555 You'll see this after the next 6hr Support site update period.
