Ruckus T310 Omni to 100m diameter coverage
rodrigo_jaques
Is T310c right AP for middle to high density placed on a kiosk beach to serves internet traffic for mobile and tablets?
Is a R510 indoor AP located and protected right below kiosk ceiling flap able to handle more connections and more robust solution?
thank
Im new with Ruckus APs.
Jaques.
2 REPLIES 2
eizens_putnins
Valued Contributor II
Even so they look very different, from RF point of view T310c is  actually more-less identical to R510 AP, it is just rugged to be used outdoors.  So if located in same way, results will be exactly the same. For 50 m it must be definitely OK. Normally, you want AP a few meters high -- 5m pole would be ideal. And you install AP with antenna facing down.
rodrigo_jaques
Can T310C handle this aplication with good user experience u think? Or t610 at least is recommend?
thanks
Type a product name
