11-09-2021 10:36 PM
Is T310c right AP for middle to high density placed on a kiosk beach to serves internet traffic for mobile and tablets?
Is a R510 indoor AP located and protected right below kiosk ceiling flap able to handle more connections and more robust solution?
thank
Im new with Ruckus APs.
Jaques.
11-12-2021 04:23 AM
Even so they look very different, from RF point of view T310c is actually more-less identical to R510 AP, it is just rugged to be used outdoors. So if located in same way, results will be exactly the same. For 50 m it must be definitely OK. Normally, you want AP a few meters high -- 5m pole would be ideal. And you install AP with antenna facing down.
11-14-2021 03:34 PM
Can T310C handle this aplication with good user experience u think? Or t610 at least is recommend?
thanks
