Ruckus R650 WiFi Speed Suddenly Slows Until Reboot
josephkim
I recently purchased a Ruckus R650 (purchased through authorized dealer) running Unleashed Firmware v. 200.12.10.105.129 with a very simple single access point configuration.
Everything initially looks good (350+ mbps speed). However, the network will randomly and non-deterministically suddenly slow to below 1mbps. The rest of the network (hardwired LAN computers) is functionally completely normally with full speeds.
The AP will stay in this bad, slow state until I manually reboot it. Then, the AP is instantly back to normal (350+ mbps) speeds until it randomly gets back into the bad state in 1-3 days.
Initially, I thought there must be a hardware issue so I purchased another R650 for testing, but the new device is exhibiting the exact same behavior.
Any ideas? I suppose I can return the devices, but I had heard great things about Ruckus (unfortunately, my experience has been pretty bad thus far...).
10 REPLIES 10
After a running time of 43 days, upload is slow down again today. I tested with iperf3 and it dropped to 150mbps. The problem occurred only with tcp upload. tcp download, udp download and udp upload are fine.
After a reboot it's back to 550mbps.
R650 Unleashsed 200.13.6.1.319
Hello Jungyu_park, thanks for sharing it.
We have a new unleashed version - 200.14.6.1.179
You might want to try this version.
Bruno Andrade | Principal TSE Bulldog Americas | RCNA | CWNA | CWDP
Follow me on LinkedIn
Thanks for letting me know that information.
There doesn't seem to be a fix for this in the release note, but I'll give it a shot.
The 200.14.6.1.179 firmware also had this issue and I eventually stopped using ARC.
The current uptime is 32 days and there are no symptoms of slowdown yet. The feature will obviously add one layer in the middle to classify the packets, and I think this is where the problem occurs while processing the packets.
Pushpendra
Hi Support
We have R650 5 APs. We have the Current firmware version 200.14.6.1.199. We are facing suddenly slow internet browsing and video call drops on Wi-Fi. But at the same time on LAN, all browsing and video calls are smooth. We have facing this last 15 days.
