03-18-2024 08:31 PM
I have a Ruckus 510 AP and have noticed that the system logs output the following logs below repetitively. What are these types of logs and what is required to be performed to 'select next response'
Mar 19 11:12:46 RuckusUnleashed_R510 AP kernel: [7069431.456898] FWLOG: [129745027] vap-0 AP PS: AID=18 select next response
Mar 19 11:12:46 RuckusUnleashed_R510 AP kernel: [7069431.456885] FWLOG: [129745027] vap-0 AP PS: AID=19 select next response
Mar 19 11:12:46 RuckusUnleashed_R510 AP kernel: [7069431.456871] FWLOG: [129745027] vap-0 AP PS: AID=6 select next response
Mar 19 11:12:46 RuckusUnleashed_R510 AP kernel: [7069431.456858] FWLOG: [129745027] vap-0 AP PS: AID=21 select next response
03-19-2024 10:50 AM
Hope you are doing well.
The above logs refers the Station has not accessed the AP for a specific time(30 second), and AP will force to treat the station as "awake" mode, and send the packets to the station.
This is Atheros FW debug information sent in the middle of TX VI packet to Power saving clients. It is likely to be seen, when a Power Save client is on a video call.
This message was printed out by Atheros FW for debug information.
Typical trigger is that UE goes to Power Saving mode during some video streams are still forwarding by AP and AP keeps data in buffer.
After UE comes back from PS mode, AP will send data out to UE.
It is just informational message and harmless.
Sunil Acharya
03-21-2024 07:35 PM
@Sunil_Acharya Hi good day to you. May I know if there are ways to stop the information from being printed out?
04-04-2024 07:07 AM - edited 04-04-2024 07:11 AM
Hi @iTouchComputers ,
Good Day
Since it is used for debug information the message cannot be stopped.
It's glad to assist you. if you are satisfied with solution please updates as solution provided on the portal
Sunil Acharya
