Ruckus R510 provide only specific wlan in a specific ap
Good day,
we already use Ruckus R510 to provide guest network and corporate network in our conference rooms.
We dont have any controller we just use 3 Ruckus APs for that.
Now i want to install more APs in our storage area but they should only provide a different wlan (for example SSID "Storage") and the existing corporate WLAN for example.
But i didnt find any option to configure which ap provides which ssid.
Is that possible? If not, is it possible with zonedirector?
7 REPLIES 7
paul_van_der_cr
Contributor
If I'm correct, it will be possible in the next release of Unleashed to to create separate AP or WLAN groups in Unleashed
That would be awesome, will hope for it. Thanks !
you could always logically separate them in different layer2 domains. That will allow you to separate which APs should broadcast which SSIDs.
What specific use case are you looking for?
You want to have 1 cluster but be able to selectively choose which APs will broadcast which SSIDs? Sort of like
Zone A -> broadcast SSID 1 on all APs.
Zone B -> broadcast SSID 1 and 2 on AP 1 and 2 but not 3 and 4?
