we already use Ruckus R510 to provide guest network and corporate network in our conference rooms. We dont have any controller we just use 3 Ruckus APs for that.
Now i want to install more APs in our storage area but they should only provide a different wlan (for example SSID "Storage") and the existing corporate WLAN for example. But i didnt find any option to configure which ap provides which ssid.
Is that possible? If not, is it possible with zonedirector?
I'm a little confused here.. if your APs are standalone, you should be able to log into them separately and configure whatever SSID you need.
Your statement "which AP provides which SSID" almost sounds like you are trying to do it from a controller, in which case you can also do it there by setting up the appropriate WLAN groups and binding them to either individual APs or AP groups you create.
It's not possible to create separate AP or WLAN groups in Unleashed. I'd recommend you migrate to either Zone Director or Ruckus Cloud to get the additional functionality you require.
Here's a list of Unleashed limitations, compared to ZD functionality:
No layer 3 roaming. All APs must be in the same subnet.
Tunneled WLANs are not supported.
IPv6 is not supported.
No interface to communicate with SmartCell Insight, SPoT, or the ZoneDirector Remote Control mobile app.
No North Bound Interface to pass client authentication responsibility to an external entity.
