Ruckus R500 with firmware 2.6.0.0.370 connect to VsZ with version 5.2.0.0.685
fahrizal_zulqif
Dear All Master,
we have problem with our AP Indoor, we have Ruckus R500 with firmware 2.6.0.0.370 connect to VsZ with version 5.2.0.0.685, in now cannot register to VsZ, anyone can help me to solve this problem.
Fahrizal Z
5 REPLIES 5
sanjay_kumar
RUCKUS Team Member
Hi Fahrizal,
Could you please reconfirm the R500 firmware version? If it is 2.6.0.0.370 version, then this is not supported on the vSZ running on 5.2.0.0.685.
If this is the first time connecting this AP to this vSZ, then you might need to upgrade to Standalone version and then add it to the vSZ.
fahrizal_zulqif
Hi Sanjay,
Thanks for your answer our question, but you can inform to me about stand alone version, how version update to support our AP??.
Fahrizal Z
sanjay_kumar
RUCKUS Team Member
Hi Fahrizal,
Since this is a old version, I'm not sure about the exact path.
However, you can try upgrading to the least standalone version 9.8.1.0.101 from the below link.
https://support.ruckuswireless.com/software?filter=68#firmwares
You can also try to put 100.0.0.0.127 on the AP, but I do not want the AP to brick.
Try a step by step upgrade from 2.6.x to 9.8.1.0.101 >> 9.8.2.0.15 >> 9.8.3.0.14 >> 100.0.0.0.127 >> 104.0.0.1347
Once on 104 version, you should be able to connect to the vSZ on 5.2 version.
fahrizal_zulqif
Dear Sanjai,
thanks for information, but after i upgrade to firmware 104.0.0.1347, the AP still cannot join to controller, any idea again?
Fahrizal ZImage_ images_messages_5f91c45c135b77e247a44db4_4232b99fc6cc707c1770de9c8a5d3982_RackMultipart20200206603851rz8-53119894-0fe6-4543-8bac-95f0ac24753f-74400279.jpg1580975318
