06-26-2023 01:30 AM
Hi Everyone,
I have recently upgraded the Ruckus R320's firmware from 112.0.0.0.920 (ZoneFlex Solo) to 200.14.6.1.179 (Unleashed).
As of now, everything is working fine.
However, I would like to know the differences between ZoneFlex Solo and Unleashed version, in terms of features and functionality.
Should I be concern on any aspects of having converted the Ruckus R320 from ZoneFlex Solo to Unleashed version?
Would appreciate your responses! 🙂
Thank You.
06-26-2023 02:29 AM
Hi @CCX
Below are the information I tried to put in based on your query. I hope this answers your query:
RUCKUS Unleashed APs are designed for small and midsize businesses with a single location or multiple locations with up to 128 APs, 2048 clients and 8 switches per deployment.
Unleashed integrates the controller and access point features installed on a access point (So called Controller-less.
No extra hardware controller required, no per AP license required), a enterprise wifi solution from Ruckus for small business. The concept is similar to IAP (Instant Access Point) from Aruba, Mobility Express from Cisco.
Even tough the Unleashed included many ZoneDirector features, Unleashed does not provide the entire ZoneDirector feature set.
Some of the Zone Director features are either not supported, supported but with limitations, or are currently unsupported but planned for a future release.
Standalone:
Standalone or Solo firmwares makes the AP to run independent and and its configurations are local to taht AP only. If you are having more than 1 AP and running on standalone firmware, both the APs will be working independently and you need to manage\configure by logging into it individually.
Running a few in standalone your basically setting everything manually which can be fine depending on your needs.
The main advantage you loose is centralized control, and more automated stuff a controller offers like channel coordination, load balancing, managing all the APs, centralised configuration, roaming etc.
06-26-2023 02:45 AM
Hi @sanjay_kumar ,
Deeply appreciate your response!
To sum up, you are indicating that Unleashed may have better management of multiple APs, while also having lesser features of ZoneFlex (to be implemented in the future).
As for me, what I care more about would be its reliability to provide network connections.
As long as the Unleashed does not affect the functionality of my Ruckus R320, I guess its safe to say that there should be no concern upgrading it from ZoneFlex to Unleashed?
06-26-2023 07:38 AM
Hi @CCX
Having the APs in the controller\centralized managed version is more reliable and easy to manage when dealing with multiple. Even with Single AP you can use Unleashed version which will have more functions when in Standalone AP.
