10-17-2021 12:43 AM
Dears ,
kindly I wont to ask if we can configure Ruckus 7055 AP to work as standalone and how ?
Thank you ,
Regards ,
10-18-2021 04:00 AM
And by the way, recommended by David Solo 104 version doesn't support ZD7055, so don't try to use it...
I am not sure if the 100.1 is the latest, but at least it's one of the last supporting this old AP. It is always mentioned in release notes for the version, what APs are supported. Never try to load wrong model firmware to AP -- in the best case upgrade will fail, in the worst you'll brick the AP.
10-19-2021 01:03 PM
@david_saez Thank you
