01-03-2023 10:57 AM - edited 01-03-2023 11:12 AM
With my previous gear (Mikrotik CAP ACs flashed with OpenWRT), I was able to get 500-550 Mbps on an ideal case on the 5 GHz band (80 MHz) on my Macbook, and 300 Mbps on my phone running iperf3 connected to a wired server on the same switch as the access point in download mode (-R).
Now with a Ruckus R710 on Unleashed, I get a little slower speed. The connection seems great and range is miles better but it seems odd I can't reach faster raw speed!
Clients specs and iperf3 results
Wired client:
MacBook #1 wifi reported connection:
MacBook #2 wifi reported connection:
Samsung Phone:
AP specs
House spec
Experiments / Overall impressions
The speed is consistent and great. I tried various other channels and country codes, sometimes the speed was lower, but never higher. I tried lowering the power too. I tried to swap the R710 with a R510 and I kind of got the same speeds.
Oddity
The phone roams great when going from the 5 GHz to the 2 GHz band, the iperf3 connection doesn't skip a beat, but when roaming back to the 5 GHz channel, the iperf3 test has 2-3 seconds of 0 mbps before going back full speed. At least the connection doesn't drop, but I find it odd. My old access point (Mikrotik running OpenWRT) wasn't doing that with the same phone.
Conclusion
As I said, my Mikrotik 2x2 access point was giving me higher raw speed and I read in numerous places that I should be able to get around 550 mbps running iperf3 with a 5 GHz (80 MHz) wifi5 access point in ideal scenarios...
Thanks for the help/pointers!
01-06-2023 04:02 PM
Turns out I tried to have a R710 as master, a R510 as slave, then connect each MacBook to each, then do an iperf3 between the MacBooks.
I get 600 Mbps in one direction and 500 in the other so I guess everything is right.
What's weird is the APs are connected to the same switch. I guess the problem was the wired computer...
