R510 Unleashed - disable 802.11b
daniel_hainich
Hi Guys,
iam running a mesh with 3 R510 AP with Unleashed Firmware 200.11.10.5.195.
There should be an AP-Group Option for configuring 11n only Mode.
But there is no such Option. This one is missing.
Image_ images_messages_61ec58064ad08869ee0087d1_2a428a8bf2036378be744d140acf674f_2022012220_11_29Window-3f70605f-a15f-4b2a-89ce-27113e78a0a4-1633034033.png
What did i wrong? Why there is no Option as described in Online help?
Image_ images_messages_61ec58064ad08869ee0087d1_9a11f982c48707488828a1f8e8b674a2_2022012220_14_16Window-792d440d-0f41-40ed-9a2c-08a937716a94-2112061450.png
Thanks,
Daniel
15 REPLIES 15
david_black_594
Contributor III
Yeah, that is annoying.  Every now and then Ruckus decides to remove or hide functionality that might confuse the 2% of users who are inexperienced while complicating life for the other 98%.  They also removed proxy-arp at some point.  You can disable 11b by enabling OFDM mode on each WLAN.  If you have more than one wlan, the commands should be executed for each wlan.  Here is an example to enable OFDM only mode on two wlans - "Blue1" and "Blue2"
login:
password:
en (or enable)
config
wlan Blue1
ofdm-only
exit
wlan Blue2
ofdm-only
exit
exit
exit
If desired, you can enable proxy arp with the command "proxy-arp" after the ofdm-only command.
You  can also use the command "show" to verify your changes and see other wlan info.
To disable ofdm-only or proxy-arp, insert the word "no" in front of the command ("no ofdm-only").
daniel_hainich
hi,
i changed the wifi to ofdm-only, but there was a client connecting with 11b.
i blocked/released the client but it still was connecting with 11b.
david_black_594
Contributor III
Can you CLI to the wlan context and run the show command and verify if the state of OFDM Only is "Enabled" ?
en
config
wlan Blue1
show
daniel_hainich
WLAN Service:
  ID:
    1:
      NAME = Guest
      Tx. Rate of Management Frame(2.4GHz) = 6.0Mbps
      Tx. Rate of Management Frame(5GHz)   = 6.0Mbps
      Beacon Interval = 100ms
      SSID = Guest
      Description = Guest
      Type = Standard Usage
      Authentication = open
      Encryption = wpa2
      Algorithm = aes
      Passphrase = ***
      FT Roaming = Enabled
      802.11k Neighbor report = Enabled
      Web Authentication = Disabled
      Authentication Server = Disabled
      Called-Station-Id type = wlan-bssid
      Tunnel Mode = Disabled
      Background Scanning = Enabled
      Max. Clients = 100
      Isolation per AP = Disabled
      Isolation across AP = Disabled
      Zero-IT Activation = Disabled
      Priority = High
      Load Balancing = Enabled
      Band Balancing = Enabled
      Wifi6 = Enabled
      Dynamic PSK = Enabled
      Dynamic PSK Passphrase Length = 62
      Dynamic PSK Type = friendly
      Dynamic PSK Expire Time = unlimited
      Dynamic PSK Validity Period = first-use
      Limit Dynamic PSK = Enabled
      Limit Dynamic PSK Number = 4
      Shared Dynamic PSK = Disabled
      Rate Limiting Uplink = Disabled
      PerSSID Rate Limiting Uplink = 0
      Rate Limiting Downlink = Disabled
      PerSSID Rate Limiting Downlink = 0
      Auto-Proxy configuration:
        Status = Disabled
      Inactivity Timeout:
          Status = Enabled
          Timeout = 1 Minutes
      VLAN-ID = 120
      Dynamic VLAN = Disabled
      Closed System = Disabled
      Https Redirection = Disabled
      OFDM-Only State = Enabled
      Multicast Filter State = Disabled
      Directed Multicast= Enabled
      802.11d State = Enabled
      Force DHCP State = Disabled
      Force DHCP Timeout = 10
      DHCP Option82:
          Status = Disabled
          Option82 sub-Option1 = Disabled
          Option82 sub-Option2 = Disabled
          Option82 sub-Option150 = Disabled
          Option82 sub-Option151 = Disabled
      Ignore unauthorized client statistic = Disabled
      STA Info Extraction State = Enabled
      BSS Minrate = Disabled
      DTIM period = 1
      Directed MC/BC Threshold = 1
      Call Admission Control State = Disabled
      PMK Cache Timeout= 720 minutes
      PMK Cache for Reconnect= Enabled
      NAS-ID Type= wlan-bssid
      Roaming Acct-Interim-Update= Disabled
      PAP Message Authenticator = Enabled
      Send EAP-Failure = Disabled
      L2/MAC = No ACLS
      L3/L4/IP Address = No ACLS
      L3/L4/IPv6 Address = No ACLS
      Precedence = Default
      Proxy ARP = Disabled
      Device Policy = No ACLS
      Vlan Pool = No Pools
      Role based Access Control Policy = Disabled
      SmartRoam = Disabled  Roam-factor = 1
      White List = No ACLS
      URL Filtering = Disabled
      Application Recognition & Control = Disabled
      Apply ARC Policy = NO POLICY
      Client Flow Data Logging = Disabled
      Wlan Bind = all
      Client Connection Data = Disabled
      Transient Client Management = Disabled
      80211w-pmf = Disabled
