07-21-2023 07:57 PM
Model : T750SE
AP and Moving Vehicle are surrounded by many metal materials. In this environment, a thick bar made of AL material is blocked right in front of the AP. The MV may move away from the AP by as much as 49 meters. Even at this time, the signal size is not significantly reduced, but I heard that signal quality and signal size are separate. It is said that radio waves are reflected and reflected before reaching them. In fact, we know that a clear environment is good between AP and MV.
Is it bad for the environment where the bar of thick AL material is blocked right in front? I would appreciate it if you could give me some advice on how to make things better.
07-25-2023 03:40 AM
Hi @TaicrafT
Unlike omni-directional antennas that radiate signals in all directions, T750SE uses BeamFlex which directs transmit energy towards the best path to the receiving device and unlike fixed-positioned directional antennas, BeamFlex dynamically configures its "beam" on a per-station, per-packet basis, to achieve omni-directional coverage. So the impact should be less but for more clarification on beamflex and impact of materials etc kindly follow below :
Beamflex :
https://www.youtube.com/watch?v=0G7CfExG1oE
Materials and Obstacles :
https://www.youtube.com/watch?v=p4fUJkqNjFs
RUCKUS RF Basics - RF Reflection :
https://www.youtube.com/watch?v=OV2g7c-98X8
Until unless there is any major issue in performance of your MV clients you can relax.
Best Regards
Vineet
