Maximum throughput R650 / R550
beni_mahler
For a customer with a 10G fiber internet connection, we are trying to maximise the throughput on his R650. We are getting up to 1.4 Gbit/s when directly connecting to the router of the provider and around 2 Gbit/s if we connect a PC to the 2.5G Ethernet port where the AP hangs.
When connecting the R650 the upload is fine (arount 1.3 Gbit/s) but the upload is below 400Mbit/s. What we have tried to improve so far (without success):
- set channel width to 160MHz
- disabled background scanning
- Switched 2.4G off
- set the wifi to ofdm-only
- set the bss minrate to 12
- manual channel selection (tried various channels that are completely free from other Radios)
Any idea is appreciated.
7 REPLIES 7
James
RUCKUS Team Member
"When connecting the R650 the upload is fine (arount 1.3 Gbit/s) but the upload is below 400Mbit/s."
Could you confirm if the download is 1.3 Gbps and upload is 400 Mbps respectively?
Also, is this AP managed by a ZoneDirector, Smartzone, Unleashed, or Ruckus Cloud?
beni_mahler
We are using a symmetric 10/10 Gbit/s internet connection. The UPload is fine and the DOWNload not so much. I know usually it's the other way round. We are using unleashed.
James
RUCKUS Team Member
Try a packet capture from the 5 GHz radio of the AP, when doing a speed test. Please make sure to stop the capture pretty soon as the file size can go large in a short period of time, when running an internet speed test.
Login to Unleashed AP > Admin & Services > Administration > Diagnostics > Packet capture > choose 5 GHz radio button > check your AP > click "Add to capture APs" > Use local mode and filter with user device mac address > Start the capture > run speed test on device > stop with after 3 seconds of "download speed" testing.
Open this file using Wireshark. Check these captures for data packets sent from AP to your user device.  Click on one such packet > Expand "802.11 radio information" > check for data rate negotiated between AP and user device.
Should look something like this:
Squozen
Contributor III
What speeds do you get when running iperf to a device on network?
