LBS Disabled on wifi0 - Can't connect to vSPoT
michael_stone_7
I'm trying to get my 7372 APs to connect to our vSPoT instance via a ZoneDirector 1100.
We are running the latest firmware on the ZD and APs i.e. 9.10.0.0 build 218.
Everything looks configured correctly but I get the following on the ZD Monitor > Location Services.
Image_ images_messages_5f91c3e1135b77e2478c481d_4cbaf5dd386eb7cf36fa67bd79a110de_RackMultipart201506117081fryzi-6b3a1a02-a3b8-4291-ab6f-c4be4e7f5c3c-1294000332.JPG1433986826
So the ZD is connecting OK to the vSPoT but the APs are not connecting.
When I look at the individual APs, I can see the following.
rkscli: get lbs-server
State: Enabled
URL: 175.x.x.x
port: 8883
Venue: vspot
OK
rkscli: get lbs wlan0
LBS mode:
LBS Disabled on wifi0 OK
I can't find anything on the ZD configuration menue to enable LBS for a specific WLAN - it only enables per AP group.
Thanks,
Michael
7 REPLIES 7
sid_sok
Contributor II
Do you have wlan(s) on both radio?
Hi Sid,
There are two WLans at the moment which operate without restriction across the APs.
Thanks,
Michael
monnat_systems
Valued Contributor II
Mike..
Are the AP's connected to controller?
check --> ZD GUI --> Monitor.
APs are definitely connected to the ZD as I can login successfully. See Monitor > Access Points below and note that one of our APs is physically disconnected.
Image_ images_messages_5f91c474135b77e247a98bc2_0a8bafe2460a5ba12adae6617413a17a_RackMultipart201506124567wwgn8-d6f3e5f0-56fd-42de-934b-d682c3eb3894-794195901.JPG1434070380
Thanks,
Michael
Labels
