03-23-2023 05:13 AM
I want to define each of my managed access points to a specific IP. I don't want them to use the DHCP pool of adresses. When I'm trying to define an access point, I always receive the manager IP and can't define the other 24 managed access point to define their adresses.
10x in advanced'
Shirley.
03-23-2023 05:24 AM
Hi @Shirley
What type of controller are you using ? Manually via CLI you can define a static IP using below :
set ipaddr wan <IP_address> <subnetmask> <gateway>
Note : The above command needs to be run on each AP individually
Best Regards
Vineet
