Showing results forย
Search instead forย
Did you mean:ย
How to Remove 7055 Access Point from Wall Mount Bracket?
I have a number of 7055 Access Points wall mounted in some condos.  I can't figure out how to remove these units from their wall plates.  It does not appear that there are any Torx Bracket Screws installed.
Any suggestions would be appreciated, so I don't have to destroy my walls to remove these units.
Thanks,
5 REPLIES 5
dan_kern
syamantakomer
Community Admin
Community Admin
Hi Mike,
Refer below two documents and see if that helps.
ZF7055 Adjacent Wall Plate Bracket Installation Instructions
ZoneFlex ZF7055 Quick Setup Guide
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
@syamantak_omer These documents show how to install the units, but not how to remove them from the wall plate.  From some of the manuals I read, it indicates that the AP snaps into place and then you can secure it with the Torx screws.  I don't think that there are any Torx screws installed on my units.  My problem is that I can't figure out how to unsnap the unit to get it off of the wall plate.
Hi Mike,
I hope someone from forum who has hands-on experience can help you here.
Syamantak Omer
