Showing results forย
Search instead forย
Did you mean:ย
How to Re-flash an Unleashed AP back to standalone or ZD firmware
Hi. I flashed a T300 to use the Unleashed firmware and now I  would to convert this back to the original firmware but cant see an option within the unleashed GUI to do this. Is this possible?
10 REPLIES 10
klaus_heidelber
Yes, this is possible. First you have to set it to factory default settings. Second in the Setup Wizard after connecting to the configure.me SSID in the wizard is an option for show ap info -> choose Upgrade, there you choose the standalone image, flash the device and reboot -> Done
Esteemed Contributor II
Documented in KBA-5193: Can I convert an Unleashed AP to ZoneFlex Standalone/Controller managed mode?
https://support.ruckuswireless.com/answers/000005193
stephen_hall_60
Contributor
hi,  this KB needs to be updated.  this option is no longer visable in any of the setup steps of unleashed 206.x
i dont see a show AP info option at all
