How enable 160 Mhz or 80+80 MHz on AP r730
namezys
Hey,
I'm trying to use Ruckus R730.
I found confusing information in different documentation:
* it's clear that it supports 20/40/80 Mhz
* in some places (for example documentation about ZC) I can see that it can support 80+80/160
To check how it works I installed vSZ v6.0.0 (the last version that has firmware for this AP, v6.1 uses old firmware)
But in the interface, if I'm trying to override parameters for 5Ghz I see only options for 20/40/80.
Also, it is connected using a 48V (at least 2A) DC adapter.
Does it actually support 80+80/160 Mhz and can I active it (even in SOLO mode)?
Thank you.
1 ACCEPTED SOLUTION
Orlando_Elias
RUCKUS Team Member
Hello @namezys
I found in the datasheet for the R730 this is what they support:
https://webresources.ruckuswireless.com/datasheets/r730/ds-ruckus-r730.html
This is how it looks like in the datasheet for the R650 which supports 80+80
Let me know your comments or questions.
With regards,
Orlando Elias
Technical Support
7 REPLIES 7
namezys
Maybe you have software/firmware that is not available public?
@namezys
What is the version of your R730? The newest version is available for this AP:
https://support.ruckuswireless.com/software/2768-ruckus-solo-access-point-114-0-0-0-6565-ga-software...
About the performance in solo mode, please collect the follwing commands in both solo and SZ for us to understand better: get cwmode wifi1 /wifi0, get wlanlist, get channel wifi1 /wifi0, get txpower wifi1 /wifi0, get scanresults wifi1 /wifi0
With regards,
Orlando Elias
Technical Support
after double recheck it changed its mind and started to work perfect even in Solo mode.
BTW it's helpful information
