Heartbeat Loss on R510's
Primrose_home
I am a different user but am having similar issues to others. Heartbeat loss on both APs at the exact same time, every 12 hrs. Then they come back online a minute or two later at the same time. The issue started occurring about a month ago.
Here is what I have done:
  • Set separate WLAN 5 Ghz and 2.4Ghz channels
  • Increased background scan times from 20s to 300s to 600s, no difference.
  • Set static IPs for the APs; did not make a difference so changed back to DHCP
Please let me know what else to look at.
Date/Time Name Severity Activities Action
2023/05/31  11:24:31AP Has JoinedHighAP[RuckusAP_Upstairs@1c:3a:60:1e:a5:80] joins with uptime [1555667] s and last disconnected reason [Heartbeat Loss]Clear
2023/05/31  11:24:29AP Has JoinedHighAP[RuckusAP_Downstairs@1c:3a:60:1e:a2:a0] joins with uptime [80961] s and last disconnected reason [Heartbeat Loss]Clear
2023/05/30  23:24:19AP Has JoinedHighAP[RuckusAP_Downstairs@1c:3a:60:1e:a2:a0] joins with uptime [37752] s and last disconnected reason [Heartbeat Loss]Clear
2023/05/30  23:24:19AP Has JoinedHighAP[RuckusAP_Upstairs@1c:3a:60:1e:a5:80] joins with uptime [1512456] s and last disconnected reason [Heartbeat Loss]Clear
2023/05/30  12:57:10AP Radio OnHighRadio [2.4G] of AP[RuckusAP_Downstairs@1c:3a:60:1e:a2:a0] is ONClear
2023/05/30  12:57:10AP Radio OnHighRadio [5G] of AP[RuckusAP_Downstairs@1c:3a:60:1e:a2:a0] is ONClear
2023/05/30  12:56:07AP Has JoinedHighAP[RuckusAP_Downstairs@1c:3a:60:1e:a2:a0] joins with uptime [60] s and last disconnected reason [AP Restart : application reboot]Clear
2023/05/30  11:24:08AP Has JoinedHighAP[RuckusAP_Downstairs@1c:3a:60:1e:a2:a0] joins with uptime [10271] s and last disconnected reason [Heartbeat Loss]Clear
2023/05/30  11:24:07AP Has JoinedHighAP[RuckusAP_Upstairs@1c:3a:60:1e:a5:80] joins with uptime [1469244] s and last disconnected reason [Heartbeat Loss]Clear
2023/05/30  08:35:05AP Radio OnHighRadio [2.4G] of AP[1c:3a:60:1e:a2:a0] is ONClear
2023/05/30  08:35:05AP Radio OnHighRadio [5G] of AP[1c:3a:60:1e:a2:a0] is ONClear
2023/05/30  08:34:00AP Has JoinedHighAP[1c:3a:60:1e:a2:a0] joins with uptime [62] s and last disconnected reason [AP Restart : application reboot]Clear
6 REPLIES 6
Hi Syamantakomer,
As far as I can tell the APs are getting steady power. The reboot happens every 12hrs so it is not random and seems to be on a schedule.
Thanks,
Patrick
Hi @Primrose_home,
I am not denying that switch may be giving power, but it is worth checking why it is suddenly bouncing all the APs.
Checking switch POE logs may help here, or power up one AP using POE injector or power adapter, see if that AP goes down with others or not.
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
