Enable mesh on t300?
I have a legacy Zonedirector with mostly 7762s and I recently obtained a t300. It successfully joined ZD and updated firmware but does not seem to have mesh enabled. According to this https://support.ruckuswireless.com/articles/000001673 the t300 should be able to mesh with 7762s. How do you enable mesh functionality on the t300? thanks
6 REPLIES 6
This is correct, mesh support on T300 started with 9.10 version and above. This is why you are not getting the mesh option.
Please upgrade the ZD to  9.9.1.0.52 and then to 9.10.2.0.114 for T300 mesh support.
As per release notes of 9.10.2, T300 and 7762 both are supported on it.
https://support.ruckuswireless.com/documents/3266-zonedirector-9-10-2-mr2-refresh8-release-notes/dow...
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
Got it, thanks
