08-11-2023 02:49 PM
CTL light not on for Access Points
08-12-2023 10:34 PM
Hi @jsun
Is this happening on all APs and is this a controller managed AP or standalone or Unleashed. If you could answer these I would be able to help better since CTL light is specific for each scenario and are you having any trouble with AP performance ?
Best Regards
Vineet
08-13-2023 11:49 PM
I believe it’s unleashed. It’s only off for one of the two access points. I can connect to them but no Wi-Fi. It’s made working impossible because I can’t connect to the router/modem reliably from my office.
12-04-2023 09:24 AM
Hi @jsun,
Did you get the solution for this or need help.
If this is unleashed, could you confirm if you are Lennar home owner?
