AP green light wont come up on controller
keturlennar
Hi team
We had power reset and controller went into boot mode with all light as amber.
I factory reset the controller, now lights are green but the port connecting AP doesnt turn green. Any suggestion?
Rukus is down since a week. Please help.
5 REPLIES 5
To log into the CLI of the ICX using SSH, you can follow these steps:
  1. Open an SSH client application such as PuTTY or Xssh.
  2. Enter the IP address or hostname of the ICX switch you want to connect to.
  3. Specify the SSH protocol and port number (default is port 22).
  4. Provide the login credentials, including the username and password associated with the ICX switch. (super/sp-admin by default)
  5. Press Enter or click on the "Connect" button to initiate the SSH connection.
Once the connection is established, you will be logged into the CLI of the ICX switch, where you can execute commands and configure the device.
If you encounter any issues or have further questions, please let me know, and I'll be glad to assist you!
With regards,
Orlando Elias
Technical Support
