04-12-2023 03:26 PM
I have an Unleashed setup with 2 x R510 and 2 x new R550.
One of the R510 is the Master.
I have 3 x SSIDs (on 2 x frequencies - 2.4 and 5) which push out fine showing 6 x SSIDs on the R510 units.
The R550 units only pick up 3 of the SSIDs - eg. with SSID1, SSID2, SSID3 and variants, the 510 units have
SSID1 (2.4), SSID1 (5), SSID2 (2.4), SSID2 (5), SSID3 (2.4), SSID3 (5)
However the R550 units only have
There is nothing in any logs that I can find to indicate any issues.
I have tried factory resetting.
I have created a new AP Group and pushed config.
What else can I try here?
04-12-2023 04:27 PM
Hi @DM-EFEX,
You can try making R550 as Master, including that help us with below information.
04-12-2023 08:41 PM - edited 04-12-2023 08:41 PM
Hi @DM-EFEX
Please login to the R550 CLI (SSH) and enter the below command to see if the SSID is broadcasting on 2.4 and 5 GHz.
get wlanlist
You should see the 2 entries for the same SSID, 1 for 2.4 Ghz and 1 for 5 GHz.
WLAN ID for 2.4 GHz will be from Wlan0.
WLAN ID for 5 GHz will be from WLAN32.
You can send us the output if you do not see 2 entries.
Also, On the SSID settings >> Advance Options >> Radio Control >> Enable WLAN on : is selected for "All Radios"
04-12-2023 08:55 PM
Forum won't allow me to upload screenshots so...
Firmware: System version 200.13.6.1.319
Firmware on all APs match that version.
1 SSID users 802.1X EAP with WPA2 and RADIUS auth (this one works)
the other 2 SSID use Open WPA2 with PSK (one half works, one doesn't work)
04-12-2023 08:57 PM
get wlanlist on R550 output
** Ruckus R550 Unleashed AP: 302202018420
Warning: AP is in Unleashed-Managed mode
Current or latest Unleashed: 10.0.1.239 / 80:03:84:0b:18:c0
Any configuration changes made in CLI may conflict
with the Unleashed's management and
will cause undefined results.
rkscli: get wlanlist
name status type wlanID radioID bssid ssid
wlan0 up AP wlan0 0 80:bc:37:4a:70:80 ssid1
wlan100 down MON wlan100 0 00:00:00:00:00:00
recovery-ssid down AP wlan102 0 00:00:00:00:00:00 Recover.Me-0A7 080
wlan32 up AP wlan32 1 80:bc:37:8a:70:80 ssid1
wlan33 up AP wlan33 1 80:bc:37:ca:70:80 ssid2
wlan101 down MON wlan101 1 00:00:00:00:00:00
recovery-ssid down AP wlan103 1 00:00:00:00:00:00 Recover.Me-0A7 080
OK
