08-31-2021 12:34 AM
sz-144 R750 configuration
The phenomenon that the connection to the wlan is cut off occurs only in mac book
Problem solved when using ssid clone
May I know what is the cause?
09-13-2021 02:06 PM
It is a very short description to provide a root cause.
Without looking into the logs and packet captures, it may be hard to confirm what is causing this issue.
What is the software version of controller and APs?
Open a support case if problem is coming back after some time. It is also good to keep one AP in problematic state so that support can use it for troubleshooting purpose.
