So has anyone had any luck connecting a Phillips Hue Bridge to the IoT module? Does it require any specific Plugin or should it connect without any plugins?
If
the Phillips Hue Bridge supports Zigbee/ Zigbee 3.0 or BLE, it can be
connected to our IoT module. Can you check the product specifications
and confirm if it has that capabilities?
