I have 4 motorola handheld guns roaming between 6 overlapping 7363 access points with Zone Director 1100. The guns are running a simple wavelink telnet application. They are sitting on a separate open WLAN with no authenticaion but with an MAC ACL. Intermittently, the guns are having problems re-establishing a link to the access point(bars that indicate signal strength go from full to none, and the handheld indicates that it lost connection with the server), even though they are within the range of them. It doesn't happen often but its annoying enough. It usually takes 10 - 20 seconds to re establish a link. What settings should I check? Thank you!
I
