Increase logs in all events ZoneDirector 3000
jonathan_salvem
Hello all
Hope you're well !
I am wondering if we can increase the maximum log into "All Events".
It's limited to 2500. When this limit is reached, the oldest events will be overwritten when new events occur.
Image_ images_messages_5f91c3da135b77e2478b0952_0ef60173214aaf4832e6ece10e678a91_RackMultipart20160414867171ni8-a8ae844c-2ef4-4d22-9551-40fa5669c41b-718209027.jpg1460620848
Can we increase that limit ? Or there is another way to see much logs ?
Thanks a lot for your reply
Cheers,
JS.
6 REPLIES 6
max_o_driscoll
Valued Contributor
My ZD 1125 and 25 APs produce a lot of logging! 50-100 lines a second is not unusual.
If you have a big deployment your log can get a tad on the bulky side. Just bear in mind when you wonder where all your disk space went.
[nearly 700,000 entries in the 3h since earlier post, tee, hee].
You can limit/filter your Syslog output, if you look on your ZD, Configure/System page, Log Settings section - Show More, Warning and Critical Events, Critical Events only.  These show All, Most, or only Critical messages, and current code has further Syslog Facility levels if you wish.
Type a product name
