Showing results forย
Search instead forย
Did you mean:ย
Increase logs in all events ZoneDirector 3000
Hello all
Hope you're well !
I am wondering if we can increase the maximum log into "All Events".
It's limited to 2500. When this limit is reached, the oldest events will be overwritten when new events occur.
Image_ images_messages_5f91c3da135b77e2478b0952_0ef60173214aaf4832e6ece10e678a91_RackMultipart20160414867171ni8-a8ae844c-2ef4-4d22-9551-40fa5669c41b-718209027.jpg1460620848
Can we increase that limit ? Or there is another way to see much logs ?
Thanks a lot for your reply
Cheers,
JS.
6 REPLIES 6
Esteemed Contributor II
Perhaps Syslog would be a helpful alternative?
+1 for syslog, helps lots especially when you need to filter and search
Since syslog is being mentioned here's a relevant thread from a while back (saves me repeating myself)!
https://forums.ruckuswireless.com/ruckuswireless/topics/centralize_log_viewers_analyzers
You guys are just awesome ๐Ÿ™‚
Thanks a lot ! I am going to create a VM with that serveur.
Can be very helpfull for other stuff also I guess.
I'll let you know if I am stuck !
See ya and have a great week-end,
JS.
