Hi Ali,
Please enable Rouge AP detection under AP zone settings and give it few minutes all the Neighbor SSIDs should be visible now, but triaging the location depends if you have floor maps done.
This is help your purpose.
Check user guide in future if you have any queries else contact support they should be able to help you to implement what you intend to do.
Abilash PR
